Renaming fuel tank?
Steve SR
Maybe I missed it, but I see Left Fuel tank qty and right, but I only have a single tank in the fuselage. Did I miss that, or can I change it from Left to just Fuel tank?
TIA
First, you should be able to delete the unused widgets in SETUP MENU > EMS SETUP > SENSOR INPUT MAPPING… menu. Then, in SETUP MENU > EMS SETUP > SCREEN LAYOUT EDITOR.
Second, your user config file should have a section that starts with an entry like this:
ems_user_cal={
valid=1
name=FUEL R LEVEL
First, make a backup copy of the original file and store it in a safe place. Then, rename the FUEL R LEVEL section to FUEL LEVEL. After that, you could also set valid=0 for the following two sections that are for FUEL L LEVEL and HEADER LEVEL, but that may not be necessary if you deleted those widgets from the screen. This of course assumes you used the right tank input to the EMS for your tank. That should work, but I've never done that, so I won't swear by it. If all else fails, you can restore the backup file.
Steve SR
Not that hard, actually. Go into Setup menu, EMS Setup, Sensor input mapping, select Fuel Level, and pick or write your own. Easy peasy, Thanks to Don at Dynon Tech support.
