Regarding the parameters you may have modified to your plane (RPM ranges, voltage, amperage, Caution/Warning values for any sensor you modified originally) all you need to do is export the User Settings file from the original screen. This contains all the parameters. Import the file onto the HDX and all your settings will be there and correct. The engine readings will be positioned along the bottom of the screen as is standard for the HDX. You will initially have the default layout if the HDX is new or has been reset to factory defaults but this only means which items are displayed and where. All of the parameters you monitored before will be available but you will have to place the items you want to see in the position you wish to view them. After importing the User Settings each (RPM, voltage, amperage etc) will have the color bands and Caution/Warning bands you originally set. It is a very simple process.
