If you did a little research in the Trig Install Manual, you will find that the RS232 format that the Trig TX56/57 units use is the Garmin SL-30 protocol, which is also the GNC215 protocol, so they should be compatible with the Trig input/output. Below is cut from the Trig TX56/57 install manual. I have always been able to load the NAV frequencies from the SkyView into the NAV side of my SL-30 using the nearest VOR function under MAP, but it loaded it in to the standby window, and I needed the panel transfer button to load it into the active window to work. Hopefully, they added a transfer button in the NAV screen, like in the COMM screen so you can remote swap the standby and active frequencies like you can on the COMM’s.
If this is all true, then there is a good chance that the VAL NAV 2KR remote NAV unit will also work as they also use the SL30 protocol, if there is a transfer button on the HDX NAV Button that will swap the nav frequencies. The VAL NAV2000 does work with the HDX, as I install one for a friend in his RV7 to get his instrument rating. I have been telling Dynon for years they needed this function, and since now they are partners with a company that has a NAV receiver, they are doing it it. Now if Trig can come up with remote COMM and NAV units to free up panel space, and they will have a better mousetrap.
