RF filter for Dynon EMS
Janekom
South Africa
Some years ago I have seen an RF filter made up of back to back connectors (male and female) that gets connected between the connector from the EGT and CHT probes and onto the EMS. Does anyone perhaps have a circuit diagram for it. I have an RV7A where the EGT and CHT readings spike when clicking the PTT. Thank you and much appreciated.
$6 cheaper direct from L-Com.
How old are the Dynon units ? The symptoms you describe were an issue for a short time, & yes, temporarily fixed by using the L-Com 9, 25 & 37 connectors. Dynon improved their later units to prevent this from happening.
There’s also the possibility of poor bonding/grounding & cheap eg RG58 creating the problem ??
Cheers, Jake
Thank you all. I did not mention that I am in South Africa. The plane is a 2006 model. Equipment possibly from 2005 vintage. We will try Digikey as they do deliver and is represented here in South Africa. Their shop does show stock. RF wiring checked already. The owner is a Amateur Radio man of note.
