# 2 EGT, CHT issue
Wizzo442
I have a D-180 connected to a Lycoming O-235. All cylinder CHT and EGT readings are accurate on EMS start-up (they read ambient), but #2 EGT and CHT are inaccurate immediately on engine start-up. #2 CHT reads anywhere from ambient to 100F and stays there, #2 EGT reads 700F and stays there. Other 3 cylinders are accurate. I tested both probes with a heat gun and they respond appropriately. How do I know if its a connection issue at the DSAB vs. faulty probes? Thanks.
Wizzo442
I removed the spade connectors and soldered all 16 probe/harness connections. Are OLC-1 connectors better?
Move the sensors to another cylinder and see if the problem moves with the sensors. If it does not, then I would say you've got a cylinder not firing.
