2 GPS's into HS34?
blueflyer
Can I run a Garmin 400W, an IFLY 740 and my SL30 through the HS34?
If yes, would I connect the 400W to HS34 pins 11, 13, 25, 25 and connect the IFLY to HS34 pins 10,12,22,24 and connect the SL30 to HS34 pins 15 and 2?
I don't think (correct me if I'm wrong) that the ifly has ARINC output, so you'd use the other serial port - not the second ARINC port - to connect it to the HS34. But beyond that - assuming that it has NMEA output that is compatible (this post suggests it should http://dynonavionics.com/cgi-bin/yabb2/YaBB.pl?num=1409845662), your setup should work.
blueflyer
yep, my error, the IFLY does not have ARINC output. Thanks for the confirmation all else.
