My #4 CHT has started intermittently telling me "shock cooling" during all phases of flight, to include taxi after first startup. In cruise, my #4 CHT is within a few degrees of the other CHT's and it does not fluctuate more than 5 degrees or so. I still get intermittent "shock cooling" indicator. I have the shock cooling warning system set at 50*/minute.
Also, my #1 EGT has started reading much lower than all the others. Previously, in cruise, all EGT's were within 20-30 degrees of one another. Now, #1 is always reading about 100* lower.
When leaning, I can sometimes get #1 to get to peak EGT at the same time as the others. But, it will still end up reading about 100* cooler than the others.
I noticed on the last flight, when I turned my battery on prior to starting, that the #1 EGT was jumping around from ambient to 1100*.
I have not touched anything under the cowl that would cause these issues. Could it be a poor ground causing both these issues?
