2 SV-COMs - flip-flop switch
maus92
If you install two SV-COMs, will a remote flip-flop switch only work with one radio?  As I understand the wiring, the com select switch only changes the mic input.
southtarnation
I love flying! Wiring, ...not so much.
If you wire both radios to the same flip flop switch, they will both flip regardless of the position of the mic transmit switch you use to switch the ptt between the two radios. You will need a second flip flop switch for the second radio IMO, you do not want both radios flipping every time you want to flip one because they are on the same switch. I just hooked up the flip flop to the primary radio.
maus92
I was thinking that maybe you could use a DPDT switch: one side switches the com input, and the other side selects between flip-flop circuits on the radios...?
