Elitefortlanlgey
We are using a 24 volt system with a regulator that allows a charging range of 28.5 - 28.9 Volts. The Skyview reports the charging voltage as 29.1 at times. How accurate is that reading?
More importantly, the regulator has an over voltage protection circuit that is set to 32 volts which is higher than rated for the Skyview. How do I provide adequate protection against over voltage with the accuracy needed?
