28 Volts for Autopilot / Heated Pitot?
rckol
Although the Dynon EFIS and EMS products seem to be set up to run on 12V or 28V, it appears that the heated pitot is 12V only and I have been unable to determine what the situation is with the AP servos.
If I want to incorporate the heated pitot and AP, am I pretty much locked into a 12V system, or is there a workaround (or forthcoming product changes) to allow their use in a 28V system?
Thanks.
The servos are 28V compatible.
The heated pitot is 12V, and there are no changes planned. It was not feasible to make this device a 10-30V device like our others since heating elements are tuned to one voltage. We don't have plans to make a 28V pitot since demand is very low.
I do believe there are 28V-12V converters that are out there. Maybe a RV (motorhome) store?
PhantomPholly
Some alternators have provision to tap the alternating current before the diodes. If you do this, you can hook up a small transformer with 2:1 windings to step down 28v to 14v, then put in diodes to get DC power. Then just put it through a circuit breaker like everything else...
