5.5 Firmware Update for D10/D100 Series Available
5.5 Firmware Update for D10/D100 Series Products
We've just released firmware version 5.5 for the Dynon EFIS-D10A, EMS-D10, EFIS-D100, EMS-D120, and FlightDEK-D180. Firmware for the EFIS-D6 and EFIS-D60 is unchanged and is not affected by this release.
5.5 contains a few small fixes but does not add any new features to the D10/D100 series of products. The fixes include:
EFIS fixes:
Fixed: Autopilot NAVSRC lost messages which caused the autopilot to drop down from NAV to TRK or HDG mode.
Fixed: Autopilot altitude hold that was offset by tens of feet from the desired target. Existing altitude offsets may take a few minutes of straight/level AP flight to self-calibrate out.
Improved: Autopilot tolerance of EFIS installations that contain higher than ideal vibration levels.
EMS fixes:
Improved: Rotax oil temperature fluctuations smoothed out (sensor type 4).
RV-12 customers with D180/D100 products will need a Vans-provided update file that allows their products to upgrade to 5.5. Dynon is currently working with Vans to make those files available as soon as possible.
The 5.5 version of the Dynon Support program, which includes the update, can be downloaded here.
Polaris
France
:) Nice, look fwd to the upgrade, will install this weekend. Question... What do you mean by "existing altitude offsets..."? Thanks, Mike.
In previous autopilot releases, in some installs AP would sometimes hold a few 10's of feet off the target altitude.
If you had this issue, the new AP will resolve this, but it will take a few minutes of flying under the AP for it to go away, it won't just be gone the first time you engage.
Polaris
France
Understood. My system always held alt about 20-40 feet higher than set, so this is a nice fix. ;)
Polaris
France
Update: just logged 6 hours xc traversing the width of France and back and could not be happier with the 5.5 update. Altitude holds now with zero deviation and the interface between my D100/D120/AP74/Garmin 695 suite is solid and consistent, with zero GPS dropouts and solid course tracking - a 100% reliable operation. Turns to  intercept nav and headings seem crisper and alt hold more dialed in during turbulence... nice job guys.   :D
