6 cylinder continental egt & cht setup
ricardo_godoy
hi,
I'm instal one skyview in my plane, I am struggling to configure ems / display.
how I can change the configuration of the display to show the information of 6 & 6 egt cht? appear only info 4 cylinder. how to config Manifol Pressure, it should show 28.5 inches, 48.9 inches but is showing .....
To adjust the EGT/CHT display, you need to go to SETUP MENU > ENGINE SETUP > SENSOR INPUT MAPPING and add more EGTs at the botttom. Or, you can load one of our canned starting setups from http://dynonavionics.com/cgi-bin/yabb2/YaBB.pl?num=1262907450.
You MAP sensor is possibly mis-wired. You'll see that railed out reading if the 5V line is going to the signal line instead. People do tend to mix up the A/B/C pins on it. So I'd check that.
