after installing my 7" displays, I noticed the font size for pretty much everything is a tad too small. when sitting in the seat of the plane, my eye balls are 32" from the panel. I didn't think it was too small when playing with it on the work bench, (eye ball distance 22")
one size bigger would probably make all the difference.
also if there is a way to sharpen the text, that would probably do it too.
regarding the backup battery, while it is in use, could you add a "backup battery time left" or "voltage remaining" readout?
I'll be doing some gliding, and plan on just using the backup batteries, with engine and main battery powered off.
