Accessing Screen Display Layout menu
Kevin D
HDX 2 screens, Software 16.5.2.
I am unable to find out how to access Display Layout, Started at page 30 in the manual and Button 7 takes me to a sub menu of DISPLAY and not DISPLAY LAYOUT.
How do I get back to DISPLAY LAYOUT to re configure each individual screen?
Kevin D
KCHD
There is no page 30 in the manual. Page 3-10 tells you to access the DISPLAY page by pressing button 7. Then, in the bottom right corner of the DISPLAY page, there should be a SETUP icon. Pressing that should give you the DISPLAY LAYOUT page.
Kevin D
Rino,
Thanks, my bad typo. 3-10 Shows DISPLAY LAYOUT 3-14 shows DISPLAY
When I press Button 7, I am taken to DISPLAY which does not have a grayed out PFD or Video on the split content and there is DIM offset on the bottom left but no SETUP on the bottom right.
I am perplexed....
Kevin D
If you don't have this screen with the SETUP button on the bottom right,..
...there may be a problem. Did you get your HDX from Dynon, or from an aircraft manufacturer, such as Vans? Aircraft manufacturers will sometimes have versions of the software that disables certain features such as this. If you got your HDX from Dynon, and don't have the SETUP button, you need to contact them. If you got it from an aircraft manufacturer, you may need to contact that manufacturer if they customize the software.
djones
Administrator
So, the setup button goes away if you have a screen role assigned in the setup menu's.
Go to SETUP MENUS > SYSTEM SETUP > SCREEN LAYOUT SETUP > THIS SCREEN ROLE and set as UNRESTRICTED
Thanks. It would be nice if that were in the manual. It says the only role choices are PFD, MAP and ENGINE.
Kevin D
Just to close the loop on this, the Dynon advice does provide access to and allowed correcting the Display Setup Menu.
Thanks Don.
When I was initializing and configuring my system I wanted one Screen setup in a " restricted " manner so various seat occupants could not
jumble up the display options.
