skydancer
RV-7 O-360 CS Prop. Dual Skyviews/AHRS. TruTrak AP
My SV-ADAHRS-200 is on it's way to Dynon for repair (the magnetic heading was off > 60 degrees).
Today I recalibrated the SV-ADAHRS-201 in my RV-7, using the Airport compass rose and the Garmin-496 magnetic heading as reference.
I start the calibration from North--> East--> South--> West, then hit "save" to complete the calibration.
After the calibration, I checked the Skyview Compass Rose, I found only North and South were accurate enough, East was off for 10 degree (read 100*), West was off for 15* (read 285*). Then I recalibrated again, this time I started from East --> West --> North --> South.
After the 2nd calibration, all four directions came out to be within 1 degree from the reference. I test twice, both came out with the accurate reading.
Any of you experienced the similar calibration issue? how do you get the problem solved?
Dynon Tech support, how do you explain this phenomenon?
