I am adding a D10A to a panel that already has a D100/D120/HS34/ with autopilot servos. I don't have an EDC for the D10A, nor a temperature probe for it, though both of these elements are available and connected to a D100. The D100 also has an internal battery backup. The D10A is to provide redundancy for the D100 during IFR operations.
My thinking is to connect the RS232 serial line of the Garmin SL30 to the D10A as well as the DSAB line of the system. The DSAB to the D10A will be connected to a switch which can interrupt the DSAB should there be a DSAB hiccup, failure or an issue with the HS34. This would then allow the D10A to revert to using the serial line (SL30) and allow navigation as well as performing an ILS approach.
I also have a GNS480 GPS/nav/com in the panel, however I understand that the GPS needs the HS34 to perform vertical navigation (reason for connecting the SL30).
Any thoughts on different interconnection scheme to minimize panel failure mode risks?
Also, will the EDC temperature sensor information from the D100 be made available to the D10A via the DSAB?
Can an ILS approach be performed with solely with a D10A? (horizontal and vertical nav, and altitude monitoring).
Thanks.
Alfio
Thanks.
Alfio
