dbwindom
RV-8
OK…Upon further review… (My original question is at the bottom of this post…)
I have a SV system wired for a Roll servo. I want to pre-wire my RV-8 for a future Pitch servo. Originally, I was planning to fabricate another NET-SERVO harness to run from my SV Hub, behind my panel, to the pitch servo. NOW…after browsing your Forum a little, I've discovered a graphic that clearly says I can tap into the existing twisted pairs of wires that are now running to my roll servo, with the wires I will run to my pitch servo.
IS THIS CORRECT?…I'm doubtful, because I cannot see how the correct inputs from the SV can figure out which servo to manipulate. MAGIC?
This would greatly simplify my wiring if I can tap off these existing twisted pairs, along with PWR and GND.
Is there any reason why I shouldn't include the Power, Ground and Disconnect wires to the harness I'm fabricating between my SV Hub and A/P servo? I'd like to put all these wires in 'snakeskin' and pull them together thru the bulkheads.
If they should be separate, then is there a desired distance to try to keep the PWR and data lines part? :
