Adjust Baro
Dynon101
I love flying!<br />
I'm reaching out to everybody to see what their pilot technique is for instances when you get a message that says "Check Baro"
I'm hoping there's a better way than what I've been doing... when I get this message I go to nearest WX and then there's a really long list of weather reporting airports all around .. so looking at the list it gives you distance and bearing (and that is great) so you have to scroll through the stack to try figure out an airport that is "near and fairly close to in front of you" ... THEN... you have to select that airport to get to the next page that shows the Metar report...
Is there a better way than this method?
What would be most helpful is when get the check baro message you could press the nearest WX and there would be the same list of airports and each would have an arrow pointing in the direction of the airport and a distance and that same first page would also show the baro setting... so it this way you would click nearest WX and look for an arrow that's pointing in front of you and see the baro right next to it...
kurtfly
Just press and hold the baro knob. It will automatically grab the closest baro setting.
I also have my Foreflight bottom line display nearest baro. That way I can see it change and tune it in before the message comes up.
Kurt
Dynon101
Not surprising that I did not know that. THANKS Kurt!!!
It's in the User's Manual, in the section entitled (oddly enough) "Barometer Setting".
