ADS-B antenna ground plane
What sort of ground plane is needed for the ADS-B antenna? If I wanted to put it into a wingtip, for example, do you think that would be possible (or would there be any significant issues like blocked field of view, if it can even be done)?
You need the same ground plane a transponder antenna needs. Either a 110mm square, or optimally anything greater than 650mm in radius.
You don't want it in the wingtip. You are trying to see ground stations, and they could easily be off your right wingtip while your antenna is in the left. The signal is line of sight, just like a GPS or transponder, so you would have very little range if the antenna had to "look" through metal to see the ground station.
Hi all - just wanted to share that starting today, Monday, December 3rd, we are now shipping the new SV-ADSB-470 Traffic and Weather receiver for SkyView. We've decided to release the SV-ADSB-470 module early, before the upcoming 5.0 firmware update, so that folks that want to get a head start on installation can.
To order, the official part number and description is:
SV-ADSB-470 UAT BAND ADS-B Traffic and Weather Receiver (US only)
The list price is $995, and is available directly from us (phone, web store, fax) as well as your favorite Dynon dealer.
Please note that this product only works in the US with the US FAA ADS-B system, as it receives on the US-only 978 MHz UAT frequency. It will not work for either traffic or weather in other countries.
The product brochure may be downloaded here, and there's some more info on the SV-ADSB-470 webpage.
The SV-ADSB-470 module requires a separate external antenna and coax cable which we do not sell; any antenna suitable for use with an aircraft transponder will work, as will UAT specific antennas. The SV-ADSB-470 antenna must not be placed within 2 feet of the transponder antenna.
Also note that for traffic reception, the SV-ADSB-470 requires the SkyView Mode-S transponder to be part of the SkyView system.  Weather reception works without the Mode-S transponder.
Finally, as previously mentioned, the SV-ADSB-470 requires SkyView Version 5.0, which will not be released for several more weeks. We are releasing the hardware early so that customers can receive and install the module in time for the software release. A pre-installation guide to physically install the SV-ADSB-470 module is be available at http://docs.dynonavionics.com now. The software release will be announced on our Website.
Just an update - Dynon released SkyView Software Version 5.0 today. This release is a big one: It adds ADS-B weather, traffic, and TFRs capability to US-based SkyView systems when paired with the SV-ADSB-470 module ($995) that we released last week.
This also means that when paired with an SV-XPNDR-26X transponder, Dynon has the only widely available and affordable ADS-B solution for homebuilts and LSA aircraft that incorporates an ADS-B Out transmission. This is important, as the transponder-based ADS-B Out transmission wakes up the ADS-B ground stations and causes them to send a traffic portrait that includes all known ADS-B targets around the SkyView-equipped aircraft.
SkyView 5.0 can be found on from our website.
