ADS-B compatability
Dick_B
I have a Dynon D-100 EFIS with blind encoder, a Becker BPX-6401 transponder; will the SV-GPS-2020 interface with current equipment to complete an ADS-B install?
Dick B
skysailor
The SV GPS 2020 is not an ADS-B receiver or transmitter. The only relationship it has to ADS-B is that it provides a WAAS GPS position source suitable for use by an existing ADS-B system in an Experimental aircraft to meet the FAA standard. Previously, a certified WAAS navigator was required to provide the GPS position to the ADS-B system.
Dick_B
My transponder has modes A, C, S with extended squitter; The EFIS with blind encoder provides altitude info; if the SV-GPS-2020 provides the WAAS capability, will it work with the existing components to meet ADS-B?
The SV-GPS-2020 will only work with the SV system & SV Transponder.
From the website --
Can the SV-GPS-2020 be used with non Dynon transponders / ADS-B Out devices?
No other ADS-B Out devices are known to currently support the SV-GPS-2020's format. Dynon Avionics currently only supports SkyView and AF-5000 installations. The SV-GPS-2020 transmits RS-232 NMEA output (115,200 baud) with additional integrity information.
