ADS-B ground or air
johnsteichen
I just got back my full ADSB report from the FAA.
I was told that I was not putting out "in the air or on the ground" information.
My GPS source is GTN 750
Is this an important issue?
Is this a settings issue?
Is this a wiring issue?
The following assumes you have a Dynon Avionics SV-XPNDR-261 or SV-XPNDR-262:
Check SETUP MENU > TRANSPONDER SETUP > AUTO ALT/GND
For most aircraft, it should be set to AUTOMATIC (AIR DATA)
This allows SkyView to automatically sequence the SV-XPNDR-261 or SV-XPNDR-262 to GND or ALT.
If you have a squat switch, and want to (or are required to) use it, set those options appropriately.
If set to NONE, you must change the mode of the transponder manually during the phases of flight.
John,
Can you share your FAA report with us? That will help us decode what the primary issue is. You can email it to us at support AT dynonavionics DOT com. Please reference this forum thread.
johnsteichen
problem solved.
the alt/gnd was set to none.
I think we are good now.
thanks for the quick solution
