ADS-B in dual band
RVDan
Frederick, MD
Love the ADS-B in functions.  It is just that one looses traffic when low around airports that don't have radar coverage and an ADS-R antenna on site.  Make a variant of the SV-ADSB-470 that is dual band.  Better yet, also make it an upgrade from the existing 978mhz only unit.
Even better yet make the upgrade free :D  OK guess that is asking way to much.
In order to see a plane with 1090 that you could not see with 978, you must:
1) Be out of a ground station range
2) That plane must be equipped with a Mode-S with ADS-B transponder, and have ADS-B activated. This is about 5% of GA aircraft in the USA right now.
Planes with just Mode A, C, or S will not appear even if you had 1090.
Dynon's ADS-B receiver is much more sensitive than the TSO requires so it can pick up a ground station farther away than coverage maps show, since they assume a base TSO device with about 15dB less sensitivity than we have.
Given all of this, you can see why we didn't think 1090 was a critical issue in the USA. The reality is that when you are out of an ADS-B coverage area, you should assume you are missing almost all the planes around you, no matter if you are single or dual band.
