thibault
- Joined
- Oct 25, 2009
- Messages
- 191
Dynon Support,
Because of the following, I think one can conclude that the Garmin 430/530 GPS sources will meet the 2020 ADS-B out position reporting requirements. I say this because those boxes meet TSO-C146A.
The Skyview installation guide seems to imply that this is not true, because it has this statement on page 11-9:
ADS[ch8208]B OUT transmissions that meet the 2020 FAA ADS[ch8208]B equipment mandate require that a TSO 146c GPS signal be directly provided from the GPS to a capable ADS[ch8208]B device (such as the SV[ch8208]XPNDR[ch8208]26X).
However the FAA document that covers approval of ADS-B Out systems (AC-20-165) has the following statement on page 6:
(1) Compliant architecture. ADS-B equipment meeting the minimum performance requirements of TSO-C166b or TSO-C154c that is directly connected to a position source meeting the minimum performance requirements of any revision of TSO-C129, TSO-C145, TSO-C146, or TSO-C196 may set the SDA = 2 without further analysis.
I think the key phrase is "any revision of". That phrase appears every time TSO-C146 appears in the rest of the document. All those other references are about specific performance requirements.
What does Dynon REALLY think is true about the ADS-B 2020 position source requirement right now based on the most current FAA guidance?
Thanks, and keep up the good work.
