ADS-B Traffic after 2016 and Dynon’s Solution
As many of you may have heard, the FAA has recently announced that they will be turning off ADS-B based TIS-B and ADS-R traffic services for aircraft that are not equipped with GPS position sources that are of sufficient quality starting in early 2016. Details of these changes can be found in this document from the FAA, which also outlines the history of this change: http://rgl.faa.gov/Regulatory_and_G...6b3b3e/$FILE/TIS-B_Service_Change_Summary.pdf
Dynon has been involved in discussion with the FAA leading up to this, and we want you to know that the SkyView system has you covered. You will not see a change in traffic coverage in 2016 if you are using a SkyView system with the Dynon transponder.
Not ones to leave a statement like that and run, we also thought it would be helpful to resolve some of the questions that might still be out there for the E-AB and LSA communities in general about this upcoming change.
Does this affect me?
This change might affect you if you have an ADS-B IN device AND an ADS-B OUT device. If you don’t have ADS-B IN yet, you aren’t getting TIS-B traffic, so it will have no effect. If you have no ADS-B OUT device, even if you have ADS-B IN, it will also not affect you, as you are currently not receiving these services. If you have a 2020 compliant GPS, or a Dynon SV-GPS-250, you will also not be affected, and you will continue to see traffic as you do today.
I have ADS-B IN and OUT. What will change?
First, this only affects traffic. FIS-B weather services are broadcast continuously to all aircraft and are not and cannot be directed to individual aircraft. Any ADS-B based weather data you get today will not change no matter what system you are using.
What might change is how much traffic you receive. This depends on what kind of GPS you have on board.
If you have a 2020 compliant GPS, nothing will change. Your traffic coverage will remain the same as it is today.
If you have a Dynon SV-GPS-250 as your GPS source, and a SV-XPNDR-261/262, you will also see no change in traffic coverage.
If you do not have a 2020 compliant GPS, a Dynon SV-GPS-250, or another GPS of sufficient integrity, you will experience reduced traffic coverage.
What will I be missing without full traffic coverage?
The ground station will no longer consider you a client for TIS-B or ADS-R services and will not send you targets from the ground station. This means that the 90% of aircraft without ADS-B OUT on board will not show up, since they are sourced from ground radar systems. It also means that aircraft with ADS-B OUT which are on a different frequency than your ADS-B IN will not appear (978MHz vs 1090MHz).
You may still see targets at times, if there is an ADS-B OUT aircraft near you that is waking up the ground station. These aircraft get a “hocky puck” of traffic 15NM around them and 3,500’ above and below. You will be able to see these aircraft. However, this is a false sense of security, as the aircraft “waking up” the traffic could be 3,500’ above you, and then you could only see targets that are above you, not below, but with no way to know that you are lacking coverage below you. You may also not see the aircraft that is waking up the ground station in the traffic picture as it does not get transmitted back to itself.
Dynon’s SkyView systems annunciate this situation as “ADS-B PARTIAL” in the ADS-B status block, instead of "ADS-B FULL".
Do I need a TSO’d GPS to keep getting full traffic coverage?
No. You never need a TSO’d device for ADS-B, even for full 2020 compliance. Just one that meets the “performance requirements” of the TSO.
Even better, this change to traffic services does not require a device that is “2020 compliant.” ADS-B has multiple levels of integrity for position sources. This change is only turning off traffic services for aircraft with zero integrity (a SIL or SDA of zero which means “unknown”). To be a traffic client after 2015, you must have a SIL and SDA of 1 or higher. A SIL of one allows a failure every 1,000 hours. A 2020 compliant GPS has a SIL of 3 and SDA of 2, which represent a very high level of integrity, allowing a false or misleading position only once every 10,000,000 flight hours.
I have a Dynon SkyView system with Dynon’s Transponder. What do I do?
Dynon believes strongly that traffic display is an important safety feature for our customers. While not a replacement for the eyeball, cockpit traffic displays reduce workload and provide reliable warnings for possible collisions. It is important to us to make sure our customers do not lose this capability.
Dynon has been working to ensure that the SkyView system is compliant with the requirements in order to continue receiving traffic after 2015. A free software update for the SkyView system will be available before 2016 which will transparently make the changes required to ADS-B OUT so you can continue to be a client to the ground stations and receive the full traffic portrait. More specifically, after this update, a SkyView system equipped with an SV-GPS-250 will transmit a SIL and SDA of 1, which is the level that is required to receive traffic after the FAA makes their changes to the ADS-B system. You will need to be using Dynon’s SV-GPS-250 as the GPS position source to your SkyView system for this to work, and the SV-XPNDR-261/262 for your ADS-B OUT. This change will maintain traffic service for your aircraft no matter what ADS-B IN solution you are using.
How is Dynon doing this?
The regulations on ADS-B OUT are performance based, meaning that what matters is how well it performs in the real world. Dynon has analyzed the SV-GPS-250 as well as the whole SkyView system and determined that the system’s performance meets the requirements for a SIL and SDA of 1.
Does this mean SkyView with an SV-GPS-250 is 2020 complaint?
Unfortunately, no. The FAR has not changed, and after 2020 in order to fly in certain airspaces, you will still need a GPS that is compliant with the performance required in § 91.227. The SV-GPS-250 is not designed with this level of integrity in mind, and cannot be used for full ADS-B compliance. Thus, after Jan 1, 2020, you will either need to be equipped with a compliant GPS, or avoid airspace defined in § 91.225.
Take me through all of this again.
There are three ADS-B GPS position source categories:
“Unknown Integrity”. Will not wake up traffic services after early 2016. This is the majority of the integrated GPS units in non-certified EFIS systems today, and in standalone non-TSO’d ADS-B boxes. Transmits a SIL or SDA of 0.
“Low Integrity.” This is the category the SV-GPS-250 will be in after a software update. This has demonstrated integrity, but not to the highest level. Good enough to wake up ground stations and get traffic after the FAA makes their early 2016 change. Is not 2020-compliant, and is not good enough to allow access to all airspace after 2020. Transmits a SIL and SDA of 1 or 2.
“High Integrity.” A device which meets all the requirements of 91.227 and the performance requirements of the applicable TSO. Allows aircraft into all airspace in the USA after 2020. Does not need to be TSO’d. Transmits a SIL of 3 and SDA of 2. Can be a standalone GPS receiver, or an IFR certified panel-mount GPS navigator.
Configurations with no change to traffic data displayed in cockpit:
ADS-B IN with ADS-B OUT and 2020 compliant GPS: Full traffic data
ADS-B IN with SV-XPNDR-261/262 and SV-GPS-250: Full traffic data
ADS-B IN with no ADS-B OUT: Partial traffic data.
ADS-B OUT with no ADS-B IN: No traffic
Configurations with reduction in traffic data:
ADS-B IN with ADS-B OUT and unknown integrity GPS: Partial traffic data
Hope all of this helps everyone understand the changes and options going forward. Please ask any questions and we'll do what we can to help.
--Ian Jordan
Dynon Avionics
DonFromTX
Texas
Wow, thanks for all that! It was a big help to me in understanding what all is happening.
The only question left in many of our minds is: Do you plan to add/upgrade/modify anything in our current GPS system to make it 2020 compliant?
Don,
"The SV-GPS-250 is not designed with this level of integrity in mind, and cannot be used for full ADS-B compliance. Thus, after Jan 1, 2020, you will either need to be equipped with a compliant GPS, or avoid airspace defined in § 91.225."
So we can't upgrade the SV-GPS-250 as it is to be 2020 compliant. However, SkyView is designed to accommodate a compliant source, and if you know Dynon you know we won't leave you without a solution for full 2020 compliance.
lgabriel
Thanks for the clear and timely explanation!
Honestly, the easiest-to-understand source for info about the 2016 and 2020 mandates has been right here on the Dynon support forums. Thanks for doing what you do.
Louis
ebke-zenith
Fairbury, Nebraska
I and everyone will be waiting anxiously for the next step from Dynon toward 2020 compliance.
Thank you so much for the assurance you are working toward that goal.
Jerry
diablouser
Am I correct that the NAv error that was introduced in 12.2 will also be corrected in the future revision? Will that error lock us out also?
Have you heard of an online support function from the FAA to get reports on our actual ADS-B performance? The guy over on the RV board must be tired of sending out reports by now. They sure need it to keep us from being surprised when we can't get ADS-B and have no way to find out what is wrong.
I surely appreciate your support and am anticipating a reasonably priced new GPS from you in the (near?) future.
Bruce Patton
Bruce,
If you have updated to the 2.6 Transponder version and are not using a certified GPS, then yes, the NACv being 0 will also prevent you from getting traffic. This will be fixed in the release before 2016 that adds SIL/SDA 1. The error is actually in the transponder firmware, not the SkyView software.
We are well aware of the FAA's compliance reports, however those reports are focused on 2020 compliance, and we haven't heard any discussions that they will be updated to make it clear if you are eligible to be a 2016 traffic client. We're doing our best to make that "just work" in SkyView.
