ADSB-472 does not show up in network
AndyHumphrey
Johnstown, OH
I have the ADSB-472 installed. When I do a network config it does not show up. However it appears to be working. I have not been able to test fly it to make sure it connects, but it says no signal. If I unplug it, it says offline, so it’s communicating. Why does it not show up in the network? Is that a problem?
maartenversteeg
Look in your circuit diagrams / wiring schematics. The ADSB-472 is not a dynon network device but is connected to the Dynon display using a serial interface. You can see the communications going on on the serial interface status page and if you see that ADSP generates data and the Dynon display sees correct 'sentences' then the communication is working
SETUP MENU > SYSTEM SETUP > SERIAL PORT SETUP
Everything you need to know is...wait for it...in the Installation Manual.
As others have said, the SV-ADSB-472 is a serially-connected device and will not show up in the SkyView Network page.
