air traffic from air avionics serial interface setting
RV7Builder
Hi,
Trying to connect the air traffic from air avionics I wonder which seriell Format the hdx expects.
I have tried a lot of different configurations
Baudrate is always on both parts the same. Tried from 4800 to 19200.
Rx From air avionics to tx hdx,
Tx from air avionics to Rx hdx
double checked.
All I get is the number of error messages increasing
I am using the serial Port 2
Nice greetings
David
TouchTheSky
David, here is the setup I am using with my Air Avionics AT-1:
RV7Builder
Hey, thank you very much.
I have tried this configurtaion already too.
The only thing is i wired the connection to Serial port 2. Should work too normaly.
I will try it again tomorrow. The only thing i can imagine ist that i did not make a reboot of the devices after changing the setup.
I only switched the air traffic Not enable after changing. Maybe this is the problem.
RV7Builder
Hi, wanted to Tell you that it works now.
Seems that a Parameter change in the air avionics Instrument needs a Power on reset to have an effect.
Nice greetings
