Airspeed Audio Alert?
TouchTheSky
Maybe I missed something but I can't find any setting where I could enable an Audio Alert e.g. if airspeed is dropping below a certain value. I don't have an AOA installed, maybe this is a reason?
RVDan
Frederick, MD
You can setup low airspeed aural warning in setup/airspeed. I have it enabled on my airplane.
AlanR
UK
I set up my AOA 3years ago, however I can't say that I have ever looked at it or had the aural warning on after the initial experimentation period!
HFMan
AOA only works if you have the Dynon AOA Pitot setup, and it also requires you calibrate it with some stalls (see the manual). Either you don't have it set up right, never calibrated it, or never approach your stall speed.
Janekom
South Africa
Seting the AOA up properly with audio makes life so much easier in that last few seconds before landing. Eyes outside where it should be and listen for the tone.
