I have been using my Viggen as a surrogate unmanned aircraft to test sensors for the Unversity of Washington. The airplane is instrumented with temp and humdity sensors, two GPSs, the EFIS D-10A, Engine monitor, flight data recorder, sensor system, a modified UAV autopilot and data links. After the the first set of test flights we published the results in several scientific journals. I sent a copy of one of the papers to Jillian a while back. I can send you another copy if you like. The pubs are listed below. I also presented the papers at a UAV conference in Australia last November. So I really use the data research puposes and would like to be involved if you guys ever change the data stream..
Publications & Papers using the D-10 data
C. B. Spinelli, C. E. Furlong, S.Yee, T. Chinowsky, A. Naimushin, S. D. Soelberg, T. Mann, R. C. Stevens, P. Kauffman, Airborne analyte detection
with an aircraft-adapted surface plasmon resonance sensor system, Sensors and Actuators B (Chemical) January (2004).
S. D. Soelberg, T. Chinowsky, G. Geiss, C. B. Spinelli, R. C. Stevens, S. Near, P. Kauffman, S. Yee and C.E. Furlong, A surface plasmon resonance
(SPR)–based sensor system for real-time monitoring of analytes that range in size from small organics to whole cells”, 7th International
Symposium for Environmental Biotechnology Chicago, June 2004
T. Chinowsky, C. B. Spinelli, C. E. Furlong, S.Yee, A. Naimushin, S. D. Soelberg, P. Kauffman, Airborne surface plasmon resonance biosensing,
Environmental Monitoring and Remediation III, Proceedings of SPIE Vol. 5270 August 2004
Charlie
