Aithre Shield config files
I have the Aithre Shield EX 2.0 CO detector installed (it works *great* by the way), and I see on their website there's a new set of parameters for the .sfg file...if these are polynomial coefficients, they're WAY different...so should I update the .sfg file to use the new values? I don't see any similar updates on the Dynon site, so this is confusing...
Thanks!
old:
low_coeff={c_x4=0
c_x3=0
c_x2=0
c_x1=77.2727272727273
c_x0=0}
New:
{c_x4=0
c_x3=0
c_x2=0
c_x1=85.0538674493846
c_x0=-39.6606183916479}
djones
Administrator
Well, there were lots of users who didn't have enhanced GP inputs available, so I worked it up with a 10K pull up so it can now be used on
any available input, enhanced or otherwise.
So I'm not sure I understand...if it's on an enhanced GP input, which configuration should be used? The old one, the new one, or either? :)
djones
Administrator
Either, the old config doesn't have the pull up resistor turned on. The new config turns on a 10K pull up resistor so it can be used on either the enhanced or regular GP inputs and the file compensates for the slight voltage shift from the pull up.
Awesome! Thanks for the info! I'll just leave it alone then.
BTW, this is a great little unit and integrates very easily into the SV system...very sensitive and beats the heck out of the big honkin' boxes from other vendors IMO!
