alpollo GX60 to Serial port 1
q2cjiii
I need help with serial port 1, setting up that port in order
to use my Apollo GX60, I had this set just after the software
came out allowing us to use the gx60 as a navigation . source.
Dynon told me how to set up the port and I have lost those
notes, I believe one of the software updates must have
corrupted that file.
thanks, Charles
Charles,
There's no special setup needed for the GX60. Set that port up as "AVIATION" format, set the device type to GPS X, and it should work. You then need the GX60 set up correctly to outpu AVIATION data on the port you have hooked to the SkyView.
As far as I know, the GX60 has worked as a navigation source since 2009 when SkyView came out, so maybe we are discussing something else? What is and isn't working on your SkyView?
Charles
I'm operating dual skyviews with a GX60 (have been operating the GX & Apollo 'stack' since 1999) , if I can help then send me a pm  ;)
