I have two alternators - the main is a PlanePower 70amp, and the standby is a B&C gear driven 40amp. When I look at the PlanePower, I see total amps as a negative number. When I look at the B&C, I see total amps as a positive number. Which is correct, and how do I change the wrong one?
You don't say which alternator is on a shunt and which is on an induction coil, or which way you WANT the current reading to read, or what the ammeter is measuring. There are three possible measurements:
- Alternator output
- Bus Load
- Battery current in/out
Personally, I like (3) as I find it the most useful if the electrical system is well designed, but most folks are (1). Generally (1), (2) and (3)-in will be positive current, and only (3)-out will be negative current (battery feeding current to the system).
If the PP alternator is using a shunt, then all you have to do is swap the shunt signal wires and the polarity will reverse.
But you have provided nowhere near enough information to give you a canonical answer.
