Folks, the dynon altitude will stabilise over a period of 5 minutes. If you saw what an altitude encoder does when you turn on an old style transponder and encoder you would see the same thing.
I have several thousand hours of Dynon operations and the altitude function is always 100% spot on. This drift you get of about 20-40 feet at start up of the panel is normal.
The other thing that affects it is when you start the plane up the pressure changes all around the fuselage and that then changes the static port pressure until you get off the ground.
Start your panel up, do all your pre flight checks, jump in, set QNH and then start your engine. You will see the static change after engine start, but you will know you are set right.
If at an airport with an ATIS/AWIS use the QNH from there.
GPS altitude can be accurate and it can be off by 60-100 feet, and as you climb it is often 300-400 feet different to the PA which is why we all use PA in flight and 1013/29.92 above transition.
