I have a D-180 and the ammeter fluctuates in the range of +/- 8 amps, everything in the charging sys has been replaced, but the problem remains. Is this fluctuation normal for the -180 like that seen with MAP? If so, could it be dampened? When the amperage drops to the lowest range the GPS (GNC-250XL) cuts off but immediately comes back on. I don't know if it is related to the amperage fluctuation or a problem in the GPS. What do you think? Any help you can give me will be greatly appreciated.
P.S. the voltage is always steady at 14.5v
Glenn Wilkinson
Glenn Wilkinson
