Hello, I've problemns with the ammeter in my Skyview, It always read -100.
I attach 2 pictures, one is with the ammeter conected and the second is with the ammeter disconted.
Any idea? Thanks.!!!
Disconnect both wires from the shunt and hook the to each other. That should read 0A. If it does not, you either have a wiring issue or the EMS is damaged. In most cases it's a wiring issue. Check continuity from each wire back to the pins on the EMS.
Please contact our Technical Support Department to arrange for a Return Material Authorization (RMA) to repair you SV-EMS-220. Call 425-402-0433 or email support at dynonavionics dot com.
I make all the checks, the wiring is ok, It look like the EMS is not working.....
