I am using a GRT hall effect sensor for my ammeter input. When attached to a GP input it does not record in the log or be used in the calculation with the VPX. I am thinking of designing a simple circuit to convert the sensor output to be used with the shunt amps inputs. In order to do this I need to know the common mode voltage range and input current requirements (or resistance) of the amps shunt input to the ems? Perhaps Dynon can comment on this as measuring the parameters in a flying aircraft is not so easy.
Merv
Merv
