Hi,
My AOA audible signal stopped working on short final yesterday. Where should I begin troubleshooting, its from a D100?
I know the system was functional, because the visual on-screen was still working perfectly. Other audible alarms from the EMS D120 seemed to work normally. Comms was also working normally.
Is there an audio test function I can use to determine whether the D100 is still physically wired into a functional circuit, while it's in the hanger?
What else could it be - I have my AOA inhibit speed set to a reasonably high speed (35kts from memory) - but this has never stopped it before, and I wasn't flying particularly slow when the AOA audio cut out either, I also accelerated to 50kts to check if it would come back on, prior to landing.... I also don't understand how this AOA inhibit function works - mine does not appear to work as promised, I can be rolling down the runway at 25kts (tailwheel down) with the AOA blaring. It seems to cut out when the ASI stops reading, not at the level I set. Of course that wasn't the case yesterday.
Any help or advice appreciated!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
