David_Prince
- Joined
- Jul 6, 2007
- Messages
- 14
I have been flying my Glasair 1TD for about 15 hours now with the Dynon D-180, heated AOA/Pitot, HS34, Garmin SL30, Garmin 296. I tried to calibrate the AOA two days ago but was unable to get it to work.
Starting at cruise airspeed 200 mph
Entered AOA calibration menu
Pitched aircraft up and down several times
From a level cruise, pushed the stall button
Slowed the aircraft and stalled, clean power off
Recovered from the stall and returned to cruise airspeed
I then let the timer finish the countdown
Slowed the aircraft and stalled, clean power on
Slowed the aircraft and stalled, flaps down power off
I pressed the Finish button
Exited all menus
After the calibration in cruise flight the AOA meter only shows a Red triangle with a single red chevron blinking below it.
If I load up the aircraft +2g's or so the chevrons increase to show red, yellow and green.
Returning to level cruise shows single red triangle and blinking single red chevron.
It seems to be displaying in reverse???
Yesterday I re-read the installation manual and re flew the calibration sequence with similar results.
Any insight into what I might be doing wrong would be helpful.
David Prince
N238SH
Exited all menus
David Prince
N238SH
