AOA display & airspeed tape
glennrv8
I have an RV-8 that I am readying for it's maiden voyage and just downloaded version 4.0 software into my D-10A.
The AOA tape displayed did not update to the new look. It still looks like the original single bar version?
Also, the airspeed tape is indicating as gray. I have not done any high speed taxi tests, but will the tape register after the plane comes up to speed?
You'll need to switch from the Classic display to Modern. You do this in the EFIS SETUP menu, under STYLE.
Have a look at this page to familiarize yourself with everything that's changed: http://dynonavionics.com/docs/support_software_200710.html
Regarding your airspeed colors, go into the EFIS > IASCLR menu and make sure each of those speeds is correct for your aircraft.
