AOA ribbon size
  • Thread starter Dennis Scearce(Guest)
  • Start date
D
I am using the D10 and have hidden the ASI and ALT ribbons to keep the screen uncluttered. My flying speed is 85 mph and stall is 47 mph. This results in a very small increment in the AOA ribbon. Is there a way to make this ribbon appear longer on the screen. Possibly as large as the ASI ribbon?
Dennis,
With today's software, there is no way to change the size of the AOA bar. We hope to feature a larger AOA display in a future software release. This software will only be availible for the D10A, so you may want to consider upgrading to the D10A when we release that SW.
The AOA actually measures AOA, so the AOA marker should be at the bottom of the range at flying speed and at the yellow/red point when the aircraft stalls. The speed range of the airplane shouldn't affect this. In fact, you should get more change per MPH on the AOA bar than most aircraft do. If you aren't getting a lot of motion on your AOA bar, we reccomend that you try reclibrating it.
