Werner_Schneider
- Joined
- Mar 23, 2005
- Messages
- 137
I do apologize if that was asked before but I've lost track a bit, just got to that flyer <http://www.dynonavionics.com/downloads/Autopilot/SNF%202008%20Flyer%20-%20web.pdf> where different configuration are compared. I have two question for this:
1.Horizontal GPS steering says with HS34 and capable GPS. Now I know, that my Garmin 196 does output steering commands from a flightplan so that should be enough? What is the difference here why do I need a HS34 (I guess only for an ARINC GPS?)
2. vertical GPS steering is literally the same, Garmin does ouput some vertical steering command ($PGRMH sentence), will that be interpreted by the EFIS already or only by the AP76 or not at all?
If I do understand it right, the AP74 adds external controls and the possibility of preselect (no intelligence at all) the AP76 does have intelligence (FD/turbulence mode) as well as signal processing for vertical navigation control (e.g SL-30 (must this be hooked up to the AP76 or still to the EFIS)) the HS34 is needed, if navigation does only output ARINC (e.g. a 430 or 530)
Did I get that right somehow?
Werner
BTW when can I order my capstan servos so I can get rid of my TT?
Werner
