Larry,
What roll mode do you have engaged when this happens? (Or does it happen in HDG, TRK and NAV?)
If it's in HDG, a compass cal might help, as it may be that the heading is drifting occasionally. If its in all modes, it could be your Torque and Sensitivity settings. I've been running at 100% and 8, and it works pretty well. In bumpy air, I'll lower it a little, though I usually just adjust the pitch setting in bumps (the pitch servo seems a little more sensitive to bumps than the roll). Of course, each aircraft is different, and you may have found your sweet spot already.
One other thought. As I'm flying a X-C, I'll occasionally get a slight wing-rock, or slight bump in the ailerons. If I disconnect, I usually find I've gone out of trim on the ailerons due to fuel burn. The bump is the servo telling me "re-trim the ailerons, knucklehead".
You may have already tried this, but it'd be cool if it were as simple as that, eh!
Best of luck, and if you find another bogey, please post it, so we can all look out for it!
Cheers,
Bob
