BrentC48
I've replaced my Ray Allen trim motor with a new one per recommendation from Vans. Previous one worked very well with Skyview/AP Module and auto trim. I've gone into EMS hardware menu to update the configuration and indicator on the Skyview screen. Screen seems fine. Manual trim button correctly moves the trim and the screen shows the current position. But I've been getting this AP TRIM MALFUNCTION error popping up when I use the autopilot and auto trim feature. No other wiring was changed so I assume its a configuration issue. Cannot seem to find anywhere a clear explanation for Trim Configuration page as to what I need to adjust to address this, but there is a numeric setting for "malfunction". Was set at 16. Suggestions?
