appearence of the EMS's screen
F-PSBA
LFRT FRANCE
what is the appearence of the EMS's screen at the first time we turn ON ?
EMS 220 skyview Lyc O320 Carb
Out of the box, when you have an SV-EMS-220 module connected and you bring up the Engine Page, it will have a default setup that is designed around a Lycoming / Continental 4 cylinder fuel injected setup. However, our SkyView downloads page links to a page that contains other engine presets for pin mappings for other engines, including Lycoming 4 cylinder carburated engines. Note that although the pin mappings should be correct and the engine page layouts should be reasonable, the redlines and other operating range parameters are not authoritatively set up for any particular engine. You will need to plug in the appropriate values for your engine.
