Approach Fast Stack
timfwalsh01
Alexandria, VA
Folks,
Does anyone have any experience using the Approach Fast Stack "wiring hub system" with Dynon products?
http://www.approachfaststack.com/
I am going to install a D-10, D-10A, HS-34,  (PMA-6000, GNS-430, GTX-327, and SL-40) in a Velocity.  I also plan to install the Dynon autopilot (once available).
Any information would be greatly appreciated.  Tim
RotaryLancair
Tim, If you decide to use the Approach Systems, I can make you a good deal on the Garmin Hub and I also have a cable for the 327. The stuff came with a partially complete Lancair kit that I bought. I originally intended to use it, but I changed my mind from most of the cables that came with it and then, when I bought my GNS430W, I had to get it prewired. So I just decided what the heck and wired everything up myself.
So the Approach Systems stuff is available if you are interested.
RotaryLancair
