ARINC Problems after loading 5.0
timfwalsh01
Alexandria, VA
After loading 5.0 software update, ARINC-429 not recognized by the network.  Checked physical connections (Using Approach Stack system).
I tested the data out (GNS-430W) on the start up menu (by only hitting enter bottom once) and only the GPS data shows up on the HSI.  The ILS bar no longer shows up.
The red light was blinking slowly, then went to solid red.  Powered system off, several times, checked connections, several times.  Red light is now solid.
Thoughts?  Tim
schwbo
I had a similar issue with ADAHRS and EMS. You need to do a system update for them and then it works.
If the light is solid red, that implies that there's a problem with the ARINC module itself. Give our tech support staff a call at 425-402-0433 and they can help you further.
