Hello Dynon people !
As per the request of the board rules I think that I have some issues related to this topic and this is the reason why I put my question(s) here polluting a little bit Steve-D's topic instead of starting a new one. If the starter of the topic or someone else think that my post landed in the wrong place please remove it.
The story begins with upgrading the software to the new 15.2.0 version on my dual SV1000 system. I've had some problems with the upgrade itself, but it seems that I solved 'em on my own after reading a lot on this forum. So after the software upgrade, playing with the screen layout in the closed hangar and with the pitot cover on the tube, I've noticed that my ASI tape indicates (and continuously jumps) in the range of 19-20-21 knots and the needle also jumps up and down too. To a similar problem the Dynon Support recommend to run a Zero Airspeed Calibration described in the Dynon installation manual.
I've already see this bad indication before on the runway, but I've think at that moment that it was from the wind blowing (my RWY is at 3000 ft AMSL in a windy enough area) or maybe from the rotating propeller somehow blowing the air against the pitot tube.
My question is : if I'll do the above mentioned calibration my speed indications on the higher ranges will be affected or not ? My fear is that after the calibration the actual reading of the 20 knots will become zero, then accordingly the reading of say the 60 kt will be 40 kt... Which is by any means not at all desirable (specially on the short final). If I'm wrong in my supposition(s) please tell me what is the logic behind this Zero Airspeed Calibration and how it works.
Any answers/solutions will be greatly appreciated,
Alex.
