My CAP unit aircraft has the Garmin G-1000. But I use my own aircraft with HDX when I fly for local Sheriff Air Group. I was just describing possible use for this functionality, But the G-1000 is the same way. In G-1000, you cannot specify a separate "target" or waypoint for the G-1000 Bearing Pointers. All you can do is assign a Navigation "source" for them. And if the Navigation source is a GPS receiver, then the "point" they are actually pointing to is not the Nav Source itself, as it is when you assign a VOR, or an ADF, (which would be silly, how can you point to the satellites?), it is the waypoint that you are currently navigating to, either via the current activated leg of a flight plan, or a Direct-To waypoint. You cannot assign any other waypoint to the bearing pointer when the Nav source is a GPS Receiver. This is what I would like to be able to do.
But as I said, I am slowly coming to the realization that the system can be used to do most of the things I used to do with a bearing pointer in other, easier, ways.
Thanks for your patience!
