Today I flew my 250 hour RV-6A with a newly installed D-10A with and EDC-10A. The D-10A replaced an electric Atitude Indicator.
One of the reasons I replaced the electric AI is because it would erroneously indicate a nose high bank in straight & level flight following a standard rate turn. Even after multiple checkouts by the manufacturer.
Interestingly, the D-10A indicates a left wing low (left bank, about 3-5 degrees) during straight and level flight, even though the ball is centered and visually the wings are parallel to the horizon. Taxiing, though, it indicates wings level.
Additionally, the magnetic compass (EDC-10) reads correctly on the ground after calibration, but in the air is off about 30 degrees East of North.
I am concerned that my problem may be caused somehow by ignition noise (one mag and one P-mag w/auto plugs and wires) since it only manifests itself when the engine is at flying power settings.
I am curious if others have seen this problem and found a solution.
Thanks,
Ben Beaird
Thanks,
Ben Beaird
