Audible warnings
AlanR
UK
Hi ,
I have SV D1000 x 2. SV-A/P Panel. Trig TY91 Comm.
I am not getting any audible warnings and rather suspect it is because of a miswiring issue.
I wonder if you could you clarify the pinout to/from wiring connections I need to receive audible warnings or maybe point me in the right direction to help solve the problem please.
Thanks,
Alan
Did you follow the instructions in the install manual ?
Are both screens audio wires connected to the audio input source (Com) ?
Was an audio setup done & tested ?
preid
SoCal
following up to Jake questions
follow the pinout on install manual and assure it's connected to correct pinout on COM as well
if YES
both displays need to be connected to COM separately. - if connected to only one and its not the master there will be no sound. in order to eliminate this. shut down 1 display and test using setup menu. than do the same for the other display. if one works than the other needs to be hooked up.
setup and tested- check that the volume is high enough in setup that you can hear it. try setting it to 100%, you shold hear some "dynon...." voice to set to correct level.
