Audio Alerts - can't hear in my new skyview....
Dkuliner
anyone can give me a hint what am I doing wrong?
trying to hear my AoA and actually any other warning and could't set it up.
Audio set up - volume is 100..
boot sound ON...
all the rest is Voice...
But still can't hear a thing  :'(.. what do I miss?  :-/
David
What intercom are you using? How is it wired? How many screens?
This is almost always a wiring issue so it's very hard to troubleshoot without knowing about your whole system.
Dkuliner
We are using dynon intercom SV-intercom-2S dynon radio SV-com-C25, a single 10" screen.
We believe the wiring was done correctly.
Will double check.
Is there anything else you suggest, in the meantime?
Don't have any other immediate suggestions. Does the intercom otherwise seem to work? Are you able to hear voice when you talk from one headset to another, for example?
D
DHeal
Here is a shot in the dark -- Does your intercom control switch have a "Mute", "Isolate", or "Pax Only" position? Do you hear the warnings when the intercom switch is set to "ICS" or "All" position, but do not hear warnings when on the "Mute", "Isolate", or "Pax Only" position?
He has the Dynon intercom, which doesn't have such a switch (since it's a 2 place intercom for sport aircraft, we didn't put an isolate function on it.
Dkuliner
We hear fine each other (intercom wise). We fly and happy with the the system, accept of that issue.
Will look into the wiring again this weekend and will let you know if anything changes.
Thank you all.
Dkuliner
found the problem.
Audio works fine
problem with wiring.
thanks for the help...
